Continue to the category
Eating the Elephant
One person can’t imagine eating a whole elephant. It’s simply impossible. But the answer to the idiomatic question remains: one bite at a time!
Master Caution
My original intent for this month’s treatise was to produce the first installment of my upcoming Kitfox build series, which I have been greatly looking forward to. However, as often happens in life, life itself got in the way.
Wanted: Engine Competition
Imagine a time not too long ago when pilots embarking on the delicious endeavor to build their own airplanes could consider multiple sources for just about any engine on the menu.
Follow Us
7,946FansLike
1,052FollowersFollow
5,930SubscribersSubscribe
Common In-Flight Failures, Part 2
This column is a continuation of common in-flight failures that I began discussing in...
Secondary Flows
Cooling within the engine compartment—oil and accessories.
Coming Back
Returning to the cockpit after a long absence.
Weep No More
9
When a fuel-tank repair means crafting your own rivets.
Fixed-pitch Props
A major advantage of a fixed-pitch prop is that it is lighter, simpler and cheaper than one with variable pitch.
