Mel Asberry clarifies the requirements for a builders log. The bottom line? The requirements are minimal: It should show that you actually built the aircraft, but its helpful to show as much detail as you can. And make sure you're in the photos, doing the work.
Van’s RV-8: Sport Plane Standard Setter
Although the RV-8 debuted 12 years ago, author Ed Wischmeyer flies a splendid builder example and notes how the design has fared over the years; by Ed Wischmeyer.
